Live matter control Print PLA
Posted: Tue Mar 11, 2014 3:56 pm
http://ustre.am/MpTj well this is print #4 using the Matter Control software and liken it so far still learning curve on slcr in general.
Have a look around and join today!
https://images.seemecnc.com/
Agreed there is a learning curve but I am glad that we are starting to see choices in the software that we use.wildideas1 wrote:http://ustre.am/MpTj well this is print #4 using the Matter Control software and liken it so far still learning curve on slcr in general.
If the layers aren't bonding I would try a temperature increase of the hotend, 5 or 10 degrees. Are you using a layer fan?wildideas1 wrote:so tell me why is it that every time i want to go live the prints look like c---- the layers are not bonding like the bust figurine did on 2nd pla print this one is splitting at the seems and i didn't change anything tried same setting different shape. hmmmm ugh.
Did you have these problems with Slic3r or are the problems related to the Matter Control software?wildideas1 wrote:well as usual it failed and yes i tried up ing temp and didn't stop just got to gooey and yes on fan. the software just stopped and shut off ext/bed and kept running like it was still fine. what i don't understand why bust worked sweet but simple vase fails.
Ideas
