Ezstruder breaking filament
Posted: Wed Mar 05, 2014 3:29 pm
Hello!
I just installed an Ezstruder ( was using Steves extruder ) It's much better except it's broken filament at around the hobbed gear twice already and ruined a print twice.
I have it aligned pretty good, double checked it.
The Filament was working fine with Steve's extruder.
The print has alot of retractions as there are spaces every 5mm or so.
I have the speed at 35 mm/s and 4.5mm retraction. EEprom steps / mm is set to 92.65
Is the acceleration too high or fast for this Extruder?
The default acceleration is 6500
thank you again!
A
thank you again!
A
