E1 to E0
Posted: Wed Feb 26, 2014 7:27 pm
by EvilFz1
i need to switch from E1 back to E0, but don't know what tab in the aurdino to find it in... also i think i blew my fuse for the extruder, its in the heat0 position, is the heat1 run off the same fuse, or can i swtich to heat1 and im good again? if so i don't know where to change that in my repetier file. thanks
Re: E1 to E0
Posted: Wed Feb 26, 2014 8:42 pm
by AndThenSome09
Configuration.h, I think they run off the same fuse though, not so sure about that
Re: E1 to E0
Posted: Wed Feb 26, 2014 9:01 pm
by Eric
One fuse is for the heat bed output.
One fuse is for the other heat and fan outputs.
One fuse is for everything else, including stepper outputs.
If any fuse is blown, you're not going to be operational. There are some creative ways to fix the fuse, but there isn't a workaround for not fixing the fuse.
