Prozacs Max Build
Prozac
Prozacs Max Build
Post by Prozac »
Just got my romax in today. Not going to start building untill friday , But I got some cleaning to do and maybe build a shelf or something. Going to try and do it all night Long!! , A build a romax printer party at my house!!
Edit/Update : Forgive my images I will clean them up and may add more after I am printing! :D , Hopefully
Re: Prozacs Max Build
Make sure you get the latest build manual.
http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf
Have a fun build!
Prozac
Post by Prozac »
Yeah just got it unpack and went through the parts list , thinking about go ahead and starting this. Was thinking though that there may be some tips and tricks to go ahead and do while in the process , was just curious if anyone has any tips or tricks?
Batteau62
Post by Batteau62 »
Re-post- If you want to paint the edges, do it before you pull the masking off the parts :D
-I would also consider this door mod: http://www.thingiverse.com/thing:171424
-Make sure you check your aluminum extrusions for trueness. Flat, straight, no twist.
There are a lot of mods, probably the best way to search for them is to make a list of part names, like "cooling fan" or "delta arms"
Have fun! ;)
Prozac
Post by Prozac »
Thanks for the info I might decide to paint the edges , like grabber green or something that pops.
GeraldO
Post by GeraldO »
As someone who painted their Rostock MAX before construction I gotta say that it definitely lends a lot to the look of the printer ;) http://forum.seemecnc.com/viewtopic.php ... 8&start=30
Providing humanity its only hope when the robot revolution begins: http://www.anti-robot.com/! Join the anti-robot revolution!
You might also try using a 1/4" wide, "fuel proof" trim tape. You can find that at any local hobby shop that caters to R/C aircraft.
Prozac
Post by Prozac »
Got some Green model paint and tested it on a scrap piece. I thought about if I need to have a base/primer/sealer but as I thought about it more the edges are sealed by the laser cut , cauterized. updated Painted Base
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0070_zpsda1ef8c2.jpg[/img]
That green looks nice on there.
Prozac
Post by Prozac »
Thanks , Im liking it , I got some ideas for maybe some yellow , radioactive like theme going on. RIght now Im in the process of Tri stepper mounts. But they seem to skip a step right before mounting the first motor. Figuring it out. Hopefully , looks like I need to mount the motor first to 68364 motor mount.
I didn't skip a step, honest. :D What part isn't clear?
Prozac
Post by Prozac »
lol just went back through and there it is , my bad , seems as though I must have skipped over that little bit 8 times last night.Damn youu bud light.
Back at it this morning.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0083_zpsd6172eb2.jpg[/img]
Ah, you got a BUI! :D
Prozac
Post by Prozac »
Was about to ask what is BUI then it hit me , good one , building under the influence. Yeah good thing I stopped last night who knows what would have happened. Well I have completed the base, got it all tight , then I seen this
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0089_zps840491eb.jpg[/img]
Did I really , I only had to take most of the screws around the door and was able to flip without removing the top.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0106_zpsdbd3b44c.jpg[/img]
Funny took a vacation day , because of my back , and building this is so painfull , but I cant stop.
I think that door flip happens more than people are willing to admit. :)
Prozac
Post by Prozac »
I thought about that , and thought about not mentioning it . Took me a kiwi crayon and filled in the Rostock MAx, looking good.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0108_zps244642b3.jpg[/img]
Batteau62
Post by Batteau62 »
The door mod I posted earlier here, would have saved you some trouble :oops: :)
I'm going to do it to mine. There are just times the doors get in the way :roll:
Prozac
Post by Prozac »
yeah was going to try and go with that but decided to start early on the build.
Prozac
Post by Prozac »
Well, back at it this morning. Working on the carriage u-joint mounts , im not having to sand anything of them , but there is side play , very little and seems equal on all 3. Is this okay ? " but has no side-to-side play." <--- I have side to side , best way to shim?
heres an updated picture.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0124_zpsvycud0cd.jpg[/img]
Batteau62
Post by Batteau62 »
Prozac wrote:Well, back at it this morning. Working on the carriage u-joint mounts , im not having to sand anything of them , but there is side play , very little and seems equal on all 3. Is this okay ? " but has no side-to-side play." <--- I have side to side , best way to shim?
You are running stock u-joints and the newer SeeMe stock arms, correct? If you have side to side play at the ujoints, I would try some elastics near the joints top and bottom. This is how Trick Laser CF arms deal with any lash at the joint. http://tricklaser.com/images/1369294770 ... 56345.jpeg And these arms works fantastic!
I would just be careful not use elastics with so much power that they cause bowing and or binding at the joint. IMO shimming is tricky, if you cause any binding at the joint it will cause you grief printing :( Build looks great! I like the green :) Good luck!
Good work! I agree with Batteau62 about the bands around the arms. Trick Laser used to sell them but I no longer see them listed.
You could send a PM to bvandiepenbos (The owner of Trick Laser) or send them
an email and ask about purchasing the bands.
Prozac
Post by Prozac »
Thanks everyone , that looks like the way to go , I should be able to fab something up that lightly holds tension on the arms , hopefully.
GeraldO
Post by GeraldO »
I got the zero last straps with my trick laser arms, so they're definitely still in production. Can't hurt to ask for them though!
Prozac
Post by Prozac »
^ I need to check into those. Just got the cheapskates assembled and adjusted , I raise it up and tightened the cams one at a time till it wouldnt fall then loosened untill it released and tightened. Seems pretty smooth everything turning like should.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0125_zpsloi47tmk.jpg[/img]
Prozac
Post by Prozac »
Just placed order for the zero lash straps , thanks for the info.
Next up axle supports and belts , getting closer.
Return to “The Build Zone”
