Prints Stopping Early on with Supports in file
Posted: Sun Feb 02, 2014 4:26 pm
Hi there,
I am a new owner of a Orion Delta (received it Friday). I am having issue with the printer stopping during prints as many have mentioned. I am upgraded to the latest firm ware .91.
Here is what I have found:
1) If I create a file with support structure the print will stop within a few minutes of starting
2) If I print without support structure the print will go all the way through, although the print may turn out bad as no support structure is present for certain builds.
3) I have repeated this this printing from the SD card and Computer and found no Differnece.
4) I am aware of the Repetier bug and have tried slicing at odd layers as suggested and this has not helped.
5) Support structures settings are what is defaut in Slic3r.
Overhanging Threshold: 0
Enforce Support for the First: 0
Raft Layers: 0
Pattern: rectilinear
Pattern spacing: 2.5mm
pattern angle: 0
interface layers: :0
Interface pattern spacing 0mm
Any ideas? I really need the support structures for my prints. I made a simple file that looks like a rectangle on a cylinder for testing but the printer justs hangs a few minutes in.
I would appreriate any help.
Thanks.
Jaganath
Raft Layers: 0
pattern angle: 0
Thanks.
Jaganath
