~$2000 gamble....
Posted: Mon Jan 13, 2014 12:41 pm
by int2str
Printed up this bracket last night and put it up on the wall:
For reference, the bracket is 23cm wide. I printed it "on end" and again is almost the tallest object the ORION can print.
What is it for? Well, that's the ~$2000 gamble
I'm betting about that much money that the printed ABS bracket is strong enough to hold this:
Again for reference, the main rotor blade is 55cm in length.
I still have to print a tail fin stand-off, but otherwise I'm very happy with how it turned out.
Re: ~$2000 gamble....
Posted: Mon Jan 13, 2014 7:31 pm
by Lochemage
I don't know if I'd go so far as to say you're gambling an entire 2k... Sure, the whole thing could be worth that... but a simple drop to the floor probably won't do THAT much damage.
Still, nice way to mount it though.
Posted: Mon Jan 13, 2014 7:59 pm
by int2str
Lochemage wrote:I don't know if I'd go so far as to say you're gambling an entire 2k... Sure, the whole thing could be worth that... but a simple drop to the floor probably won't do THAT much damage.
Heh, yes, I may have been a bit overly dramatic there
Hopefully I'll never find out.
Posted: Mon Jan 13, 2014 10:20 pm
by Blade-Breaker
int2str wrote:Lochemage wrote:I don't know if I'd go so far as to say you're gambling an entire 2k... Sure, the whole thing could be worth that... but a simple drop to the floor probably won't do THAT much damage.
Looks good. I bet you could almost hang from it.
Posted: Mon Jan 13, 2014 10:40 pm
by Toyguy
Is the STL available? I could print a few of those for my brother
Posted: Mon Jan 13, 2014 10:55 pm
by Eric
No point in making them stronger than the wall...if the screws pull out of the wall, it's not the brackets fault.
Posted: Mon Jan 13, 2014 11:18 pm
by int2str
Toyguy wrote:Is the STL available? I could print a few of those for my brother
STL + FreeCAD file attached.
The STL will most likely be useless since the skid-holes are exactly 20cm apart for this specific heli. You'll have to know what Heli he has or how far apart the skids are.
Then you can easily adjust the dimensions in the FreeCAD file.
Posted: Tue Jan 14, 2014 9:37 am
FYI: "If the wings are moving faster than the fuselage, you're in a helicopter and are therefore unsafe."
Posted: Tue Jan 14, 2014 10:26 am
by bubbasnow
geneb wrote:FYI: "If the wings are moving faster than the fuselage, you're in a helicopter and are therefore unsafe."
says a fixed wing guy... rotary wing FTW!
Posted: Tue Jan 14, 2014 10:48 am
by dbarrans
What's worse is most of the time the wings aren't even moving in the same *direction* as the fuselage.
- dan
Posted: Tue Jan 14, 2014 8:13 pm
by barry99705
Here! Here!
says the guy that flew in a flying gas station with 190,000 pounds of fuel on board...
