No idea whats going on. (Extruder? Firmware?)
Posted: Sun Dec 08, 2013 4:16 am
This isn't about a MAX, its about my Ultimaker, but for how custom everything is on it you guys should be able to help.
I have an 3mm E3D on it and it has been printing great up until today. Maybe its this SeeMe translucent green PLA that I've been trying to use, or maybe something that happened when I updated my firmware, but something happened in-between a period of transportation and the upload of the latest version of Marlin firmware (the version I had on it before was 1 or two commits older I think, but I can't use it because I accidentally broke it and it won't compile correctly). I can't get a good print out of it again for the life of me. Its something to do with the extruder/hotend, either with the firmware, or there is some possibly very burnt plastic in the nozzle of the hot end, but I can't get it to extrude consistently. In the attached images it kinda shows what I'm talking about, look at the solid infil.
(That should be fully solid but its not)
(The other side having issues too)
(This is the part that baffles me, the top 2 corners are completely solid, only the bottom 2 corners have any issues)
I could probably deal with this on a normal occasion, but the thing that really baffles me is this; before the firmware update I ran the hot end at 210C for the Translucent Green PLA and 230C for Opaque White PLA. After the transportation/firmware update, something happened (completely baffled) where I can't get any results unless I run it at 270C (those pictures were with the White PLA at 270C). Its really weird because I can get it to extrude at 230C like normal, and I started off a print at that temp and the first layer was good, but the second layer was so starved for filament it was ridiculous. I have no clue whats happening and I'm going to drive myself mad. None of this is making any sense what so ever.
One other change I made in the mix of changes was updating Slic3r from .99 something (pre-wipe on retract) to 1.0 whatever (newest).
I am just completely stumped and baffled at what could be causing all of this. Any and all help would be appreciated so greatly. Thank you SeeMe and users of this forum for tolerating a non MAX (or SeeME for that matter) machine post on the MAX forum, not really sure where else to put it...
(Also, sorry for kinda bad pictures, low light, I should have done HDR....)
