bug in repetier-host?
Posted: Fri Nov 01, 2013 2:52 pm
by aistaay
Repetier-host keeps resetting xyz max length in the eeprom to 0
problem happened when i was trying to adjust the max length in the printer settings while connected. usually its greyed out if ur connected, but i clicked on the button on the top right corner and it took me into printer settings. I hit apply, and reset happens..
I uploaded the firmware back up with the arduino software, and it works fine til i connect back rep-host. it does the reset to 0... i had to set eeprom mode to 0 in the configuration.h file.
anybody got a fix? kinda want my eeprom mode back.
Re: bug in repetier-host?
Posted: Fri Nov 01, 2013 4:06 pm
If you set your eprom mode to 1 or any number that is not 0 in your configuration.h then reupload the firmware you should have your eprom back.
