M119 doesn't show Z_Min
Vinculum
Post by Vinculum »
The subject says it all.
When i run M119 on my Kossel i get:
SENDING:M119
Reporting endstop status
x_max: TRIGGERED
y_max: TRIGGERED
z_max: TRIGGERED
Great but i need to know Z_Min for my Z-probe. How do i get it to show? I'm running the default settings since i've build it exactly like Johann's.
Re: M119 doesn't show Z_Min
You have to enable Z_MIN in the Configuration.h file.
Vinculum
Post by Vinculum »
geneb wrote:You have to enable Z_MIN in the Configuration.h file.
I figured as much but where? There are only 2 reference to Z_min in configuration.h:
#define Z_MIN_POS 0
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
If you're running Repetier firmware, try setting MIN_HARDWARE_ENDSTOP_Z to true.
Vinculum
Post by Vinculum »
Sorry, i have forgot to mention that i use Marlin firmware.
You can download the version i'm using here:
https://github.com/jcrocholl/Marlin/tree/kossel
edward
Post by edward »
I don't think Repetier calls the z-probe Z-min...I think it's in there as Z_PROBE_SOMETHING_OR_OTHER.
Since the OP has a Kossel exactly like Johann's, I'm guessing he's on Marlin (probably Johann's Deltabot branch). In that case, ensure that you have the correct pin assignment for the probe, identified as Z_MIN, in pins.h. I put -1 for the X_MIN and Y_MIN to let the firmware know there aren't any, and it seems to work. x_min and y_min don't appear in the M119 output.
Then it looks like you only need to make sure the DISABLE_MIN_ENDSTOPS is commented out, like this: //#define DISABLE_MIN_ENDSTOPS
Vinculum
Post by Vinculum »
Thanx for the replies. I've fixed the issue sort of. I am using Marlin but i was using the Marlin Kossel Branch from Johann. I've switched to the Marlin Deltabot branch and now all is suddenly OK. Weird. Must be some setting somewhere that is different. I do have another problem but that's for another topic.
