Delta Radius - Impossible
Posted: Sun Sep 22, 2013 5:57 pm
XYZ endstops are all calibrated, but when I run:
g28
g0 f8000 x0 y0 z0
Z is at least 2-3mm above print bed.
While all towers are grubbing paper.
So technically adjusting Delta Radius should fix it, but
changing "#define PRINTER_RADIUS 197.40" up/down (tried 180-280) does not seem to have any effect at all.
rest of relevant values remain the default...
#define END_EFFECTOR_HORIZONTAL_OFFSET 33
#define CARRIAGE_HORIZONTAL_OFFSET 35
Also EEPROM Is disables, #define OPS_MODE 0
I tried contributing by increasing
#define X_MAX_LENGTH 366.5
#define Y_MAX_LENGTH 366.5
#define Z_MAX_LENGTH 366.5
Now Z0 (g0 f8000 x0 y0 z0) will touch the sheet of paper, but towers (G0 f8000 x-77.94 y-45 z0etc ) will collide, and if I raise endstop screws, Z will be too high again.
So I can Have nice Z0 in am middle point only, or nice Z0 in the 3 tower point, but impossible to balance all 4 points. It's a loop!!! Please help!
g28
g0 f8000 x0 y0 z0
