Failed Calibration Attempts Gallery
Posted: Tue Jul 02, 2013 3:32 pm
Hello,
I'm working on trying to calibrate our machine and I thought that I would start to post some images of my work in progress. I'm hoping that people will spot some pitfalls and comment on how to fix these issues. So far I have been printing out TONS of calibration cubes.
...or really like a dozen.
I seemed to get those to look ok, but when I applied those settings to other parts they didn't work at all. Once the machine is calibrated shouldn't those settings for the most part apply to other models as well?
I'm not sure that I have a grasp of what the filament looks like when it's too cold, or too hot. I assume when it is too cold, it just gets choked in the head and doesn't come out or if it does it's not enough. When it's too hot I assume is gets so hot that after it comes out of the nozzle it doesn't cool quickly enough so it becomes a bit gummy and sticks to itself and the hot end. If the bed is too cold I assume that the extruded filament won't stick. So if you have a good surface and the part isn't sticking keep cranking up the temperature? When it's too hot? No idea. I assume that I run out of current before that time.
I have also been playing around with the Extruder Step Per MM value and cranking that down so that less material is being forced out of the hot end. This has definitely helped with material sticking to the heated bed better.
Why do my parts look so (excuse my language) boogery? No idea. I also don't understand why the thin walled test cubes are so irregular in their thickness.
Any comments are entirely appreciated!
[img]http://i.imgur.com/JJdwnBn.jpg[/img]
[img]http://i.imgur.com/rC4XQTw.jpg[/img]
[img]http://i.imgur.com/CuCNddJ.jpg[/img]
[img]http://i.imgur.com/ucdzz4U.jpg[/img]
[img]http://i.imgur.com/MrAY7Lu.jpg[/img]
[img]http://i.imgur.com/UZJVCqq.jpg[/img]
[img]http://i.imgur.com/9F6a4XX.jpg[/img]
[img]http://i.imgur.com/TYrlLH3.jpg[/img]
[img]http://i.imgur.com/a1RkIPm.jpg[/img]
