.35 mm Nozzle and .1 mm Layers - Possible?
Posted: Tue Jun 25, 2013 11:18 am
Hello To All.
I have a bit of a quandary and thought I'd sample the wisdom of the group. I have searched the forum very carefully and, unless I've missed something, this issue has not been addressed. Here's the scoop.
I have a print I'd like to do that requires a great deal of precision. I am using the latest "pro" version of KISSlicer, by the way. I have successfully printed the file with ABS using a .5mm nozzle and printing in .2mm layers. "No drips, no runs, no errors" (to quote the old Krylon spray paint ad). But the print is a bit "coarse" so I'd like to print in finer layers, preferably .1mm.
I would post an image of the file but the design is proprietary, so... Nevertheless, among other things the object has two sweeping arcs in it. On the peripheral ends of these arcs, and elevated above the build platform about 10 mm, are horizontal structures that rise to a height of about 10 mm. As you can imagine, I am using support to ensure the arcs and horizontal structures build well.
I have successfully printed the file as described above (.5mm nozzle, .2mm layers, etc.). But (heavy sigh!), if I attempt to print in finer layers (e.g., .15 or .1mm layers) the horizontal structures do not build well at all. The problem occurs as the gcode starts to "bridge" the support material under the horizontal structures; the extruded ABS does not span the gaps of the support material and leaves blobs as others have described in other "bridging" posts. These blobs cause defects in the horizontal structures.
I have a .35mm nozzle. Is there any benefit to swapping to this smaller nozzle and slowly refining my printer settings until I get what I want? If so, which settings should I target first? I'm at a bit of a loss and would appreciate others' thoughts.
Bill
Bill
