Frustrating Rostock Max build - still like it though
Posted: Sat May 11, 2013 3:56 pm
I intend this post to be a learning experience for others, not a whine festival. I knew I was buying a kit, I'm fine with it.
First, a few updates to the manual:
A. Fish the limit switch wires through the uprights before you mount them on to the base. It's very easy at this point, but damn near impossible later.
B. Mount your power supply loosely while building the base. If you tighten the screws you can't get the top aligned to the upright board slots.
C. Be very careful with wire lengths. Do not assume they will fit. Assume they will not.
D. Buy some crimps and practice first. Learning how on these small gauge wires will kill you and waste precious parts.
E. Inventory everything up front by walking through the directions. I was missing a crucial gear but was very kindly helped. Still, it was more delay that cost me because my free time disappeared while waiting.
Now a few problems:
1. My limit switches don't fit. At all. They are of a different design than the manual and you CANNOT connect the plugs at the top and still have room to mount the switches on the wood. If you bend the metal to make it fit, the connectors splay out too far, and now your wires are once again too short. This was the last straw for me.
2. All the wires are too short by about six to eight inches. I can't make them reach to the RAMBO anywhere. Please make these longer. I'm going to buy a bunch of extenders for the plugs.
3. I really cannot crimp to save my life. I went through half the connectors learning how, and still they pop loose. Find a different kind of connector to use.
4. My rods came ready to use, but the carriage still had to be sanded. That's nuts. Either pick some parts that don't require sanding, or mill them before shipping like with the rods.
5. The "manual" is awful. I've already pointed out several problems, and people here already know it, but this needs an overhaul badly. Once you do it, deprecate the older versions prominently on the site.
6. The parts I got don't match the manual. I had to check forums to see how to use them.
7. I got no cover. Is that normal? If it is normal, why are the cover uprights still part of the design? They just block access to the interior.
8. I got a bag of binder clips, but no hot bed glass to hold down with them. I think that's normal, but why?
I need to find a way to make the limit switches work, need to buy some replacement crimps (anyone know a supplier and part #?), and then I need to build the hot end. With my limited free time, that's another weekend away.
I can't wait for that first print. I'm pretty sure my crimps won't work right, the carriage is probably a bit loose and will need to be shimmed, and I'm really worried about the limit switches not working and the belts being damaged. But if I can get something out of that hot end, it will all be worth it.
Comments welcome.
Now a few problems:
Comments welcome.
