X-Y and Z actual movement
Posted: Sat Apr 13, 2013 2:23 pm
Hello everybody,
For my new Rostock Max (first printer!), after much trial and error, I am stumped and would appreciate any help!
My X-Y movement and Z movement are not scaling correctly. I first began comparing the actual movement of the head vs what I tell it to move in Repetier. For example, I would set it at Z5 Y80, zero in the y azis with a pair of calipers, tell it to move to Z5 Y50, and compare the actual to theoretical movement. The computer says that it moved 30mm, while the calipers measured 45mm. I adjusted the motors and now the XY movement is exact, except it screws up the Z movement.
If the XY movement ratio is 1:1, then the Z axis is at about 1:0.6 (theoretical:actual)
If i adjust the Z axis to 1:1, then the XY is about 1:1.4
I am running Polygonhell's firmware.
Any direction or help would be appreciated! Thanks!
