Can I run 3 5v fans in series on 12v?
Posted: Tue Apr 02, 2013 2:54 pm
by Av8r RC
Just like the title says. Can I run 3 5v fans in series in 12v?
I was at a local electronic component supply shop the other day. And they had some little 25mm 5v fans that output 4cfm. They were only $3/ea so I bought a handful. The idea was to use 3 of them in series to cool the print using the Rambo. I know I could just hook them up to a 5v line from the PSU, but I want more than a bang-bang control with them.
Thanks
Re: Can I run 3 5v fans in series on 12v?
Posted: Tue Apr 02, 2013 3:08 pm
by magicmushroom666
In theory it should work fine, certainly wont damage them trying.
Posted: Tue Apr 02, 2013 5:35 pm
by cassetti
I'm sure it would be fine at 100% fan speed, but you might have issues at low speeds (just a guess).
Maybe it's worth running them in parallel with a resistor for each instead?
Posted: Fri Apr 05, 2013 8:05 pm
by foshon
The cheap little motors that run fans won't care about the 7V difference. I have taken a few of these apart, the wire is the same wire that is used in 12V dvd motors.
