Firmware not compiling (SOLVED)
SoCalSteve
Post by SoCalSteve »
I downloaded the latest everything and unpacked the files.
The last time I had my machine on I was troubleshooting it, so I'm starting at ground zero with this. the problem I'm having is that the code in the repitier file does not compile. am I missing something or is there an easy fix? FYI, this is for my Rostock v2
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\SoCal\AppData\Local\Temp\ccLTqs30.ltrans0.ltrans.o: In function `__vector_17':
C:\Users\SoCal\Downloads\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX\Repetier/HAL.cpp:678: undefined reference to `stepperWait'
C:\Users\SoCal\AppData\Local\Temp\ccLTqs30.ltrans0.ltrans.o:C:\Users\SoCal\Downloads\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX\Repetier/HAL.cpp:678: more undefined references to `stepperWait' follow
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Mega or Mega 2560
Re: Firmware not compiling
Post by Mac The Knife »
Arduino: 1.8.19 may be to new of a version,,,,, try version 1.6.0 instead?
Yes, 1.6.0 is required. Anything later that that generates problematic binaries, if it works at all.
SoCalSteve
Thank you. One less problem!
This also revived my screen as well. Apparently, I ran into this issue before without a solution my printer was left idle after running the clear eeprom code.
Resolved. Thank you.
Re: Firmware not compiling (SOLVED)
\o/
