Is the Bowden Coupler removable from EZ struder adapters?
gamekorp
Post by gamekorp »
Hi,
Is the actual 'coupler' part removable so it can be replaced? I don't mean the full assembly which requires the PTC tool, I mean just the coupler with the teeth from that assembly?
How can I remove this coupler? ( I want to try a different coupler as I keep getting pucking pucks )
Thank you.
Re: Is the Bowden Coupler removable from EZ struder adapters?
If you're talking about the bit that's got the push fit teeth inside of it, then yes that whole thing can be removed - it's threaded. Just remove the bowden tube from the EZ Struder and unscrew the fitting. Replacements can be found here: https://www.seemecnc.com/collections/pa ... tc-fitting
Return to “RostockMAX v3”
