i2c error in mattercontrol after build Rostock v3 wont let me G29
sanderbing
Post by sanderbing »
After what i thought was a successful build, i did all the firmware and went to calibration but when sending G29 code thru matter control, i got the following error
<-accelerometer send i2c failed.
<-accelerometer i2c recv failed.
<-I2C Error - Calibration Aborted
<-Error:Wrong checksum
my temps are good, display is normal, except the error message.
Does anyone know what is causing this and how to fix? thank you
Re: i2c error in mattercontrol after build Rostock v3 wont let me G29
Make sure the terminal connector at the HE280 is fully seated. Also, don't use G29 - use the "full calibration" feature in the menu via the front panel.
