Part Inner Dimensions
Posted: Tue Oct 30, 2018 1:18 pm
I'm rather pleased with the outer dimensions of the parts I'm printing; on a 1" feature, it seems that I can expect a tolerance under .005.
However, the inner dimensions are consistently off. If I have a hole that's supposed to be .5" diameter, it will come out .014 under, at .486. The .014 is pretty consistent (averaged over multiple tests).
What settings can I adjust to fix this? Is this an extrusion factor error (currently set to 115%, after extended testing)?
