TPU Fail or no?
Posted: Wed Jul 25, 2018 11:07 pm
Hi All,
I was recently trying to print some TPU for the first time. Well I did print a couple calibration cubes when I first got it, but then it sat around a for a while. The first cube I printed was great (for a cube anyway). The layering was nice and the resin was some what clear (translucent green).
I am using SainSmart generic TPU in translucent green. ( https://www.amazon.com/dp/B00TI3JUSI/re ... B072LYRQ84 )
Recently I was trying to print a much more complicated model to see what was possible. However, I had a lot of trouble getting it to extrude this time around. At the beginning with TPU, I had to replace my EZStruder with a modified Thingiverse extruder to even do the cubes and now trying again with that setup (which prints PLA and ABS pretty well) I had a very hard time getting anything out. The parts finally printed, however the quality was horrible, and I had to dial up the flow rate to about 150% to get them done. Below is a link for some images of what I ended up with. As you can see there is a ton of artifact from the support removal as well from the heavy stringing. The images are from after cleaning them up. I should have take a pic of them before support removal, sorry.
https://imgur.com/a/6VNml6N
My question is this. How typical is this of the resin type? I am guessing no based on all the great images I see on the interwebs. If it is not typical, I am hoping to get some advice for the next project. I printed these at 235C, 50C Bed, 100% fill after drying the material for about 5 hours at 140F in a convection oven. FWIW, I have a stock PEEK hotend. I did notice this material drewls a lot at that temp, but lower and it would not extrude.
Thanks in advance!!
Dave
Thanks in advance!!
Dave
