ERIS - Clicking Sound, No Filament Coming Out, Unload Doesn't Work :(
Posted: Thu May 24, 2018 3:05 pm
My ERIS is totally messed up - again - this is incredibly frustrating as I am on vacation for four more days and I really wanted to finish a small project before I have to go back to work
I replaced the hotend - seemed easy enough - I made sure the tube guiding the filament was seated into the bottom of the hotend
Just before starting this print I opened a bag containing a small spool of PLA from SeeMeCNC
I loaded the PLA using the "LOAD FILAMENT" program
I began printing - all seemed good except for that dang "clicking" sound from the EZR Struder
After about two minutes of printing the part, I noticed there was no more filament coming out - nothing - zero - the first layer was about 60% printed then no more filament came out after that
And also, when I run the "UNLOAD FILAMENT" program the filament doesn't come out - the hotend heats up, the EZR Struder wheel rotates slowly as if pushing filament into the hotend, then the EZR Struder wheel spins quickly to remove the filament but the filament doesn't move - the filament remains stuck in the tube between the hotend and the EZR Struder
So, I have two questions:
#1 - How do I get the filament out?
#2 - Do I need to get a new EZR Struder &/or stepper for the EZR Struder?
Thank you
Thank you
