Non-print moves on Rostock v2 hybrid
Posted: Tue Oct 31, 2017 8:54 am
by jmargush
I've been trying to get my retraction settings dialed in, on my Rostock Max v2 w/ HE280 Hotend, and I realized my non print moves were set to 80mm/sec. I attempted to set it between 120-200mm/s and my print quality significantly decreased. I had layer misalignment and poor surface quality. Does this mean my stepper motors are likely worn, is there a fix for my issue, is there a mechanical issue other than the motors, or is there a firmware setting/slicer setting I am overlooking?
Re: Non-print moves on Rostock v2 hybrid
Posted: Tue Oct 31, 2017 9:33 am
by Mac The Knife
It depends on the motors that are in your V2, SeeMeCNC changed motors during the RMV2 run, and the new motors run on lower current. Since you are running the new hotend, I assume you are using the latest firmware, with the lower current settings for the newer motors.
Posted: Tue Oct 31, 2017 9:42 am
by jmargush
Mac The Knife wrote:It depends on the motors that are in your V2, SeeMeCNC changed motors during the RMV2 run, and the new motors run on lower current. Since you are running the new hotend, I assume you are using the latest firmware, with the lower current settings for the newer motors.
I have the automation technology stepper motors. In the old build manual it tells me to change this line: #define MOTOR_CURRENT {175,175,175,200,0}
to this: #define MOTOR_CURRENT {155,155,155,165,0}
could this be my issue? (I'm currently not home to test this.)
Posted: Wed Nov 01, 2017 11:05 am
by jmargush
I got home yesterday and updated my motor current values in my firmware, seems to be working perfectly. Thanks!!!
