(some stuff removed for simplicity)
; printer_name = Rostock MAX
; every_N_layers = 0
; num_extruders = 1
; firmware_type = 2
; z_speed_mm_per_s = 15
; z_settle_mm = 0
; bed_size_x_mm = 240
; bed_size_y_mm = 240
; bed_size_z_mm = 300
; bed_offset_x_mm = 0
; bed_offset_y_mm = 0
; bed_offset_z_mm = 0
; bed_roughness_mm = 0
; travel_speed_mm_per_s = 500
; first_layer_speed_mm_per_s = 15
[b]; xy_accel_mm_per_s_per_s = 1500[/b]
; lo_speed_perim_mm_per_s = 15
; lo_speed_solid_mm_per_s = 15
; lo_speed_sparse_mm_per_s = 15
; hi_speed_perim_mm_per_s = 15
; hi_speed_solid_mm_per_s = 15
; hi_speed_sparse_mm_per_s = 15
; ext_gain_1 = 1
; ext_material_1 = 0
; ext_axis_1 = 0
; ext_gain_2 = 1
; ext_material_2 = 0
; ext_axis_2 = 0
; ext_gain_3 = 1
; ext_material_3 = 0
; ext_axis_3 = 0
; model_ext = 0
; support_ext = 0
; support_body_ext = 0
; raft_ext = 0
; solid_loop_overlap_fraction = 1
; *** Style Settings ***
; style_name = Infill 25%
; layer_thickness_mm = 0.36
; extrusion_width_mm = 0.55
; num_loops = 1
; skin_thickness_mm = 0.8
; infill_extrusion_width = 0.55
; infill_density_denominator = 0
; stacked_layers = 1
; use_destring = 1
; loops_insideout = 1
; infill_st_oct_rnd = 0
; inset_surface_xy_mm = 0
; 'Perimeter', 1.2 [feed mm/s], 15.0 [head mm/s]
G1 F30000
G1 X9.4 Y-14.49 Z1.36 E0
G1 F900
G1 X9.4 Y-14.49 Z0.36 E0
G1 F3300
G1 E7
G1 F900
G1 X9.16 Y-14.58 E7.0217
G1 X8.9 Y-14.5 E7.0437
G1 X2.06 Y-14.5 E7.607
90mm/s is causing me problems with the "filament ejection" problem that I am trying to diagnose. Perhaps I am misunderstanding KISSlicer configuration?
