I bought a V2 and have been following the improvements on the V3:
Here's some thoughts:
- extremely slow to heat bed
I also found the V2 bed was slow to heat, but they provide a better power supply in the V3. However, if you want to run over 90C, it'll be slow and hard to get to 110.
The heated bed on the V2 and V3 are both 1.1 ohm, and my testing found that with an adequate power supply AND a dish towel set on top of it (adequate insulation), the heat bed reaches 90C in about 10 minutes. For the surface area, that's not an untenable wait.
- non modular components. if any part breaks, you have to disassemble the extremely complex extruder.
I'm confused. I routinely take off parts and put on new ones. Homemade effector platforms, several different hot ends, a dual extrusion setup, fancy blue aluminum aftermarket parts, (now unnecessary and arguably not even an upgrade) carbon fiber arms, a touchscreen controller faceplate, most of them printed on the V2 before I installed on. How is this not modular? (Also, doesn't the V3 have a quick-connect built into the new hotend circuit board thingey?)
BTW, this is NOT an endorsement of swapping out a new machine with a million different bits right away! Every smart person will tell you to build stock and enjoy using the machine, unless changing parts on the machine is what you want, more than actually printing things.
One positive experience I had in particular was that SeeMeCNC made some upgrade parts backwards-compatible. The new injection molded carriages were drop-in replacements for my original parts and have been great. No more checking carriage wheel tension!
- Have to unscrew the bowden tube in order to change filament
I've occasionally hit this (minor, 15-second-to-resolve) issue on the V2. The V3 has a redesigned extruder with a better filament path.
- uneven bed. Hassle to level manually with no way to level it in software. Even the auto level results in an uneven first layer for big parts (and therefore also bed adhesion issues).
I find this criticism hard to understand. The borosilicate glass is extremely flat. Even on my V2, before the autolevel, most people's experience is that you level the printer once, and then it just stays level until you mess with some other part of the printer.
I damaged my Rambo board
, so I can't speak to the quality of the autolevel on that controller.
There IS a semi-frequently encountered phenomenon with delta printers that makes getting a perfect first layer difficult near the bed edges in a weird triangle pattern. I haven't hit that particular problem. My first layer problems are almost always to do with my filament/bed surface/bed temperature combination, and print-specific problems like ABS edges curling up in a drafty room.
You'd be shocked how many first-layer problems are resolved by tricks like wrapping a shower curtain around the printer to trap a little heat and protect it from drafts. I just printed a 9.5" diagonal rectangular ABS part with no corner pads or brim to hold the edges down, square sides, tall enough to risk curling, and none of the corners lifted at all, and the entire first layer was visibly equal height.
I can see an argument that a delta is, theoretically, more complicated to diagnose bed leveling issues, but on the other hand, you only have three identical moving parts, the towers, and your main challenge is to make sure each is perfectly square. Compare that to a reprap-style build where the Y-axis could be slightly tilted on one end vs. the other, or uses z-screws that can bind. (Just to cite one painful example I helped a friend work through.)
- systematic small print imperfections
(I'm writing this assuming you're newish to 3d printing. Apologies if it's something you already know.)
For any open-source 3d printer, you will quickly discover that the biggest obstacle to print quality will be the particulars of the slicing software and the quirks of whatever filament you're using. I fight with small imperfections most days and 98% of the time they are traceable back to something stupid the slicer software decided to do, or wasn't quite right for that batch/color of filament. (The other 2% is because I pathologically change out parts on the printer for the fun of experimenting.)
For any high quality DIY kit (Prusa, SeeMeCNC in particular), the next biggest challenge to print quality will be the ability of the person assembling it to follow instructions very carefully.
For any cheap DIY kit, you must both come armed with electrical and mechanical expertise and be prepared for headaches stemming from imprecisely manufactured parts. I've gone this route and a lot of time with calipers, levels, and needle files was involved.
In General
I've assembled Reprap and Delta kits, and two things that stand out with the Rostock were the quality of the documentation and support. They are far above anything else I've ever seen from a small-company open-hardware project.
The biggest downside I can think of for the Rostock is simply that it's a delta printer and will be very tall relative to the printable area. The round, very tall print area is arguably a downside because many Things are rectangular, and a print that uses the entire gigantic Rostock printable area is, almost by definition, an epic long-running print.
