SD Card Reader not working?
Posted: Thu Feb 16, 2017 10:33 pm
by TKCC71
Would anyone happen to know why my SD card reader does not work? It was working fine before but now when I put the card there are no files to be seen and don't make that click noise when I put the card in? I tried multiple SD cards and still has the same problem. Is there anything I can do to resolve this?
Re: SD Card Reader not working?
Posted: Fri Feb 17, 2017 2:24 am
by Eric
No click where there used to be one could mean that the SD slot has mechanically failed on you in some way.
If that's the case, it's likely easier to replace the entire LCD circuit board assembly than to fix it. I'd check with SeeMe about replacing it under warranty.
Otherwise, they can be found cheap ($10-15) from the usual sites (amazon, ebay, etc). Search for "2004 LCD controller" (2004 stands for 20 characters x 4 lines). Most of them will include adapters for other electronics (e.g. RAMPS), but that doesn't matter since you already have the Rambo adapter.
