Axis problems
Posted: Mon Nov 14, 2016 6:59 pm
After a year of working fine my MAX v2 has recently hit a snag. Cleaning out a print head jam my Z-Axis has been giving me issues. I am having problems with the z-axis column. 2 main ways this manifests is 1.) At times things will begin to print off the plate anywhere from a mm to 200+ mm. 2.) Most of the time z-axis arm seems to not respond. The other arms move and the print head will swing back and hit the z-axis post.
Trying to test the matter-control software will show a 0 for z -axis and be unresponsive to software "manual" moving; until I hit home, then the manual software moving + or - works. The entire print head (all arms) will move up and down.
I switched computers as a test and my first print printed fine and then the same issues came about.
Any suggestions appreciated.
