SeeMeCNC Part No. to Manf or DG Part Number
briankb
Post by briankb »
I just built a Max v3 and want to update the wiring a bit and in future add another extruder.
There are a lot of part numbers listed in the various assembly guides but they are all SeeMeCNC numbers and finding them on digikey or mouser is a bit of a challenge.
As of today and to the best of my ability these parts are not available on the seemecnc store. The numbers shown below are the ones from the assembly guides.
Parts from HE280 Assembly Guide
- 26220 Cable Mount Hub (also known as a cable gland or grip)
- 26222 Non-Insulated Wire Ferrules
- 26191 High Temp Insulation
- 26192 High Temp Fiberglass Insulated Wire
- 26176 Header 2 Pin JST PH2.0 (looks to be a JST PH series)
- 26309 25mm Ball Bearing Fan (also want to confirm the gauge of wire)
Parts from Top Assembly Guide
- 26076 Micro Switch w/Lever
- Four plastic mounting posts for Rambo (need some for mounting a raspi)
Parts from Final Assembly Guide
- 26202 2 Pin Connector (for power/fans)
- 26204 4 Pin Connector (for motors)
If there is a parts cross reference available that would be ideal (seemecnc to manf part no).
Re: SeeMeCNC Part No. to Manf or DG Part Number
Email support.
briankb
Post by briankb »
geneb wrote:Email support.
ok. thanks.
Return to “RostockMAX v3”
