rostock max V3 calibration problem
flynn
Post by flynn »
Hello, i try to found what's the problem but i don't found how can i solve that problem
when i run the Gcode to calibrate on matter control, the hot end go down and hit against the X axis and if i don't stop that i think it's going to break it!
I had already clear the EEPROM, and reload the firmware, but nothing change
please help me it's my first 3D printer and i'm a beginner :/
https://www.youtube.com/watch?v=jw-dqodgBjk
Re: rostock max V3 calibration problem
Make sure the connection to the HE280's PCB is tight and that you've got the wiring to the RAMBo connected properly.
and don't post the same question in 2 different forums!
bvandiepenbos
Post by bvandiepenbos »
mhackney wrote:and don't post the same question in 2 different forums!
?really?
aren't we a little grumpy today? ...is geneb rubbing off on you?
:lol:
LOL, yes and yes. I just spent 6 hrs driving from Boston to Rochester, NY so I'm a little tired. But the fact remains, double posting is uncool!
flynn
Post by flynn »
where a double post? on my presentation? isn't a double post,
well, everything is okay, i was just an assembly's problem of "Ends stop"
my bad, i'm French and i look only the vid' on the tutorial, after reading the tutorial, i removed the small levers, and now everything works
thanks for your reply
I was referring to this one: http://forum.seemecnc.com/viewtopic.php ... 002#p98002
but it seems it is a different topic but you used the same subject for both posts, making it confusing. No worries, sorry to add confusion. Geneb is rubbing off on my...
flynn
Post by flynn »
oh sorry it's a bad handling, i
I thought my post was not had not published
it's why I published twice
sorry not voluntary : /
Return to “RostockMAX v3”
