Raspberry Pi Installation Instructions
Posted: Mon Oct 24, 2016 5:19 pm
Is there some supporting documentation on how to do a step by step install of this option? I'd like to be able to use the V3 as a wifi network printer.
Jim
Jim
Have a look around and join today!
https://images.seemecnc.com/
No, I didnt. I used the posted build instructions as that was what was available when I put it together. Does the install allow the printer to be autonomous and not use some external service?mhackney wrote:Did you look in my V3 build thread? It actually starts with the RPi and OctoPrint install and then throughout the thread additional info is posted:
http://forum.seemecnc.com/viewtopic.php?f=42&t=10836
The Raspberry Pi is solely a stand-in replacement for your computer as a printer host. It does not even HAVE to run octoprint. Technically speaking, you could run whatever operating system you want on the Pi, as long as that OS has software which can communicate with the printer.Burley wrote:No, I didnt. I used the posted build instructions as that was what was available when I put it together. Does the install allow the printer to be autonomous and not use some external service?mhackney wrote:Did you look in my V3 build thread? It actually starts with the RPi and OctoPrint install and then throughout the thread additional info is posted:
