Cura Version?
Posted: Fri Oct 14, 2016 7:05 pm
by morgandc
What is the latest version of Cura that works with the Rostock Max v3? (windows version)
Re: Cura Version?
Posted: Fri Oct 14, 2016 7:26 pm
All versions of Cura will "work with the V3". Are you actually asking for a V3 printer and slicing profile? If so, then Cura does not have out of the box support for V3 but I posted a reasonable profile in another thread here earlier this week.
Re: Cura Version?
Posted: Fri Oct 14, 2016 7:53 pm
by morgandc
Based on that, perhaps I should ask how to use the profile on a clean install of Cura. There are no printers that appear to be delta based to select initially. There is a subfolder full of *.json files that appear to be printers, but format doesn't match the profile you posted.
Re: Cura Version?
Posted: Fri Oct 14, 2016 7:59 pm
Like I said in my post, I do not use Cura actively. My understanding is you use the Import command to import the "ini" file. I tried it once.
Re: Cura Version?
Posted: Fri Oct 14, 2016 8:08 pm
by morgandc
Thanks, I will dig around a bit more and see if I find anything. I have a particular part I want to print, and was going to see if any particular slicer did better with.
