How often do you clean your nozzle?
Posted: Fri Sep 09, 2016 1:59 pm
Hi,
I have noticed that when I extrude in the air my filament kind of bends slightly to one side and I think that is because the nozzle is a little clogged. Im not using the fan... I have some .5mm drill bits that I stuck up in the nozzle and that seems to have unclogged the nozzle... But do you remove it/torch it/acetone bath it on a regular interval?
How often should the nozzle be changed if printing only basic colored abs/pla? And will a hardend e3d nozzle work with the stock hot end?
