Peek fan & layer fan questions
Posted: Fri Aug 26, 2016 5:07 pm
I haven't yet installed the peek or layer fans because my prints have been coming out just fine without them and I have not had any trouble regulating the temperature so far but I have not yet done a print that took more than 5 hrs.
I'm wondering if I should just install the Peek fan and forget about the layer fan for now because I see the advantage to having the stock plastic Peek section kept cool on long ABS prints, but I really don't see any reason to use a layer fan, unless your printing in PLA wichh I don't really do...
Can someone please give me some direction as to when I should be using either/or both of the add-on fans?
PS. Does the layer fan help the first few layers to stick better to the bed because I'm having a little trouble on prints that are circular popping off after the inth layer when the print is 75% done and around 4-5mm in height.
