Odd jumping mid print
Posted: Mon Aug 08, 2016 3:35 pm
First: I have an Orion with the new cheapskates and arms. I'm running the latest firmware (with the correct adjustments for the new parts) and have properly calibrated the extruder, PID, bed level, etc.
I've got a problem. It's not exactly random, but it is very close to being random. During a print everything will be running along just fine, then suddenly one of the axis motors will either lock up, or actively run in reverse. This happens somewhere around 1cm of build height (+/- 1mm or so), and effects just one tower randomly. Sometimes it's the Z, sometimes the Y, yet other times just the Y. One and only one tower will go off on a little journey all by it's self for a half second or so, then go back to playing well with the others. I've killed it each time this has happened, so I don't know if the "hiccup" will repeat at 2cm, or other multiple in build height.
I've sliced files using multiple slicers (Cura, Slic3r, Mattercontrol) and regardless this is happening. I've tried printing off the SD card, and over USB. Same behavior.
Before I go too far into tearing things apart I want to ask you all if this might be something someone else has encountered, and if so, what did you do to fix it??
Robert
Robert
