Is it possible to do non-ugly multi-extrusion in KISSlicer?
Posted: Sun Apr 10, 2016 10:00 pm
The filament has been carefully measured and had the flow tweak adjusted, so it's as close to perfect as I can get it. It's also running at the lowest temperature it can tolerate, which should help control drooling. Unfortunately, the huge blobs deposited on the wall aren't something I know how to fix.
Since KISSlicer's dev has gone AWOL again, and might not come back this year or ever, I was wondering if anyone knew a trick to work around this. I hate to say it, but I'm looking at MatterControl's labyrinth of configuration settings to see whether it would be worthwhile to use instead of KISSlicer. I NEED good parts, and this slicer just can't do it the way it's set up now.
