Suggestions for PDF instructions
jesse
Post by jesse »
Instructions: http://www.geneb.org/rostock-max/rostoc ... manual.pdf
One set of end stop wires (black and white) is longer than the other two sets by about a foot.
The long set of wires goes opposite the rambo board.
jesse
Re: Suggestions for PDF instructions
Post by jesse »
"It should just take a tad more than their own weight to make them "drop" when you hold them horizontally.".
That explains the feel of it a little better.
Source: http://reprap.org/wiki/Rostock_MAX, Step 4
Thanks, I'll get the PDF updated as soon as I can.
jesse
Post by jesse »
Steve responded to my email to explain how the thermistor on the Onyx heated build platform is wired.
Originally I was going to solder the thermistor to the top similar to the standard heated bed.
The photos below show that the thermistor is supposed to be soldered underneath the Onyx to the surface pads.
[img]http://i.imgur.com/GbH0W.jpg[/img]
[img]http://i.imgur.com/YuQ0a.jpg[/img]
johnoly99
Post by johnoly99 »
Jesse, john here. Yep, that's how it goes.
