Page 3 of 5
Re: Dual extruders
Posted: Mon Sep 02, 2013 9:44 am
by LorenOlepi
Wanted to update you guys on the dual hot ends as it has been great getting multi-color and multi material prints
The adapter from trick laser = pretty sweet because you don't lose any height as it comes with smaller spacers and the offset is only in one direction... the only downside is that the led ring gets blocked a little but it's no big deal and I havn't found a decent solution for a peak fan
A little tip to get your offsets good in slicer is place the amount of steps in EEprom and then offset both extruders by the same amount in Slic3r.. other wise you will always be off center
So for the trick laser with the offset in the horizontal I got
EEprom:
Extr.1 x-offset steps = -1000
Extr.1 y-offset steps = 0
Extr.2 x-offset steps = 1000
Extr.2 y-offset steps = 0
Slic3r --> printer settings --> Extruder 1:
extruder offset: x = -12.5 y=0
Slic3r --> printer settings --> Extruder 2:
I have also noticed that Slic3r always sets my second extruder temp initially to 235.. so I have just been editing the G-code to set it to the right temp
I also messed with a ton of custom tool change G-code but have found the best thing is just to do a retract of 15mm with a extra lenght of 1 mm for ABS/PLA and you wont get much leaking... a retract of 10mm for Hips seems to work fine
Also Slic3r runs M109 on every tool changes that makes the machine wait for it to reach temp... this causes little blobs where the extruders sit and a for a time delay. I've been changing all the m109's except the initial ones to M104's so that it doesn't wait = much happier :D
One last tip is to make sure randomize start point is off when doing multi-color prints as it will tend to leave streaks.
Hope this helps!!
Re: Dual extruders
Posted: Wed Sep 18, 2013 8:36 pm
by designfactore
Hey guys,
So I thought I had dual extruders working, but am having some weird problems whenever I have dual extruders active in a print.
Basically, the print will be fine for a few layers (with both extruders successfully extruding) and then, the printer behaves as if it ignores all subsequent z height changes. It prints all the remaining layers on top of each other at the same height, it "forgets" to raise for the next layer, but knows what new path it should be drawing at the next height it should have raised to. Sometimes I also hear sounds as if the steppers are skipping steps, and then the layers start misaligning.
When I switch back to all my single extruder settings, all of the problems stop, including the step skipping sounds, it prints normally, so I don't think I have any hardware issues. Loren, I do have a line that drops the z height right after the homing at the beginning of a print, thanks for that tip!
May I ask those who have sucessfully dual printed full models:
--what are the detailed printer settings in Slic3r? (Configure>Printer Settings) I've had some troubles when using "Lift"
--what version of Slic3r are you using? Maybe when I upgraded Slic3r that's what causes the problem?
--anything special in EEPROM besides extruder offsets?
--something other I may have missed in firmware other than the changes needed to get the second extruder motor and thermistor working?
Re: Dual extruders
Posted: Wed Sep 25, 2013 8:50 pm
by LorenOlepi
designfactore wrote:Hey guys,
Sorry for the late response as my notifications haven't been working? I'm running slic3r 0.9.10b within repetier host v0.90c
Here is my slic3r congif file
9-25-13.ini
(3.19 KiB) Downloaded 648 times
I'm not sure what your talking about for lift?
See my earlier posts for EEprom and my firmware file
You don't have the spiral vase turned on do you??
Re: Dual extruders
Posted: Thu Sep 26, 2013 9:02 pm
by inventabuild
Dual extruders is very tempting because I have all the hardware to do it. Just wondering if anyone tried this w/ Kisslicer because that is my preferred slicer?
Re: Dual extruders
Posted: Sun Jan 05, 2014 6:02 pm
by LorenOlepi
Running Dual E3D hotends now... here is the adapter I designed and currently using
http://www.thingiverse.com/thing:219945
Re: Dual extruders
Posted: Sun Jan 05, 2014 10:49 pm
by Flateric
And I am currently printing your adapter plates!
I had started this 2 days ago, but you beat me to the punch on it.
They look real nice so far.
Re: Dual extruders
Posted: Mon Jan 06, 2014 12:41 pm
by LorenOlepi
Flateric wrote:And I am currently printing your adapter plates!
Excellent! I'm happy to hear others will be able to use it... I may make some changes like thinning out the bottom piece but I was able to install as is and it woks just fine :D
Re: Dual extruders
Posted: Mon Jan 06, 2014 1:14 pm
LorenOlepi wrote:Running Dual E3D hotends now... here is the adapter I designed and currently using
May I ask why the top part is so thick, I'm sure there is a reason but I am not bright enough to understand.
Re: Dual extruders
Posted: Mon Jan 06, 2014 3:31 pm
by LorenOlepi
Oh your bright enough ;)
The top is "so thick" because to use the stock fan mounts I had to space out 32mm from center to center. This is too large of a gap for the stock fittings to fit through the center of the mounting plate so they needed to be on the bottom.of it. The top portion completely encases the hotends and the spacing is just enough to get the 4mm bowden tubes through the center.
Re: Dual extruders
Posted: Mon Jan 06, 2014 4:34 pm
Thank you for the explanation, now I understand. Thank you for making this available to us.
Re: Dual extruders
Posted: Mon Jan 06, 2014 5:00 pm
by dpmacri
Because of the narrow opening in the stock Rostock MAX platform, I made my dual E3D adaptor place the E3Ds as close together as possible. That way the two bowden connectors actually fit through the platform...barely. :-) I actually screw in the bowden's and align their edges *before* attaching the mount to the platform. It works although I need to make an alteration to my design for adjusting the height of one of the extruders because my 2nd extruder nozzle is a few tenths of a millimeter above the glass when the other one is touching the glass :-(.
For anyone interested, here's the link to my mount for 2 E3Ds: http://www.thingiverse.com/thing:217662
Re: Dual extruders
Posted: Mon Jan 06, 2014 5:24 pm
by LorenOlepi
No problem. Let me know if you need anything modified on it
Re: Dual extruders
Posted: Mon Jan 06, 2014 5:55 pm
LorenOlepi wrote:No problem. Let me know if you need anything modified on it
Do you remember the infill you used? I am going to print two of these and I want to make sure I make them strong enough. (I have two Rostock Maxs)
Re: Dual extruders
Posted: Mon Jan 06, 2014 6:41 pm
by LorenOlepi
I did the top at .125 and the smaller bottom piece solid but it could be over kill
Re: Dual extruders
Posted: Mon Jan 06, 2014 7:33 pm
by LorenOlepi
dpmacri wrote:Because of the narrow opening in the stock Rostock MAX platform, I made my dual E3D adaptor place the E3Ds as close together as possible. That way the two bowden connectors actually fit through the platform...barely. :-) I actually screw in the bowden's and align their edges *before* attaching the mount to the platform. It works although I need to make an alteration to my design for adjusting the height of one of the extruders because my 2nd extruder nozzle is a few tenths of a millimeter above the glass when the other one is touching the glass :-(.
Nice job! Its awesome how we both were working on the same problem at the same time :geek: As I've been putting it off for a month and finally got some time over the holidays to put one together. My heights were off a C-hair at first as well, a quick hit with the file took care of that
After having my stock dual SeeMe hotends all but touching each other I wanted to keep them farther apart this time to help with temp control and to see if it will help with the second extruder dragging into the perimeters of the print. I truly didn't mind loosing the height as I rarely print anything that reaches the MAX on my MAX
Re: Dual extruders
Posted: Tue Jan 07, 2014 11:54 am
by dpmacri
Thanks -- yours is nice too! The time off at Christmas break was what gave me the opportunity to design something (after not having found something that would work :-P), too! I just haven't had a chance to modify my file to accommodate for my height difference, yet, but that's my plan as well -- thanks for the tip!
Re: Dual extruders
Posted: Sun Jan 19, 2014 8:20 pm
by LorenOlepi
Just as a heads up... I was having a hard time leveling my dual extruders with my new mounting plate and then I placed a spring in-between the mounting adapter and the plate on each screw (3X) and now it can be leveled in no time! :D
Re: Dual extruders
Posted: Mon Jan 20, 2014 2:04 am
by dpmacri
LorenOlepi wrote:Just as a heads up... I was having a hard time leveling my dual extruders with my new mounting plate and then I placed a spring in-between the mounting adapter and the plate on each screw (3X) and now it can be leveled in no time! :D
Nice! I'll have to check that out since I've been having the same problem. I actually modified my design to account the the gap but then realized my modification wasn't printable :-P.
Re: Dual extruders
Posted: Mon Jan 20, 2014 5:47 am
I know that this is a tough question to answer sometimes but could you give a rough guess on the length and tension of the spring you used?
I have several hundred springs here and I never know which one to use.
Re: Dual extruders
Posted: Mon Jan 20, 2014 7:45 am
by LorenOlepi
[quote="Eaglezsoar"
I have several hundred springs here and I never know which one to use.[/quote]
I ended up using the ones that came from the Makerfarm Prusa leveling kit http://www.makerfarm.com/index.php/i3-p ... g-kit.html as they were the first ones I found...
They were about an inch long... and have a "medium" stiffness.
Re: Dual extruders
Posted: Mon Jan 20, 2014 8:02 am
Great, I just bought the Makerfarm Prusa I3 8" kit and it comes with that leveling kit.
Thanks so much!
Re: Dual extruders
Posted: Mon Jan 20, 2014 8:16 am
by LorenOlepi
Eaglezsoar wrote:Great, I just bought the Makerfarm Prusa I3 8" kit and it comes with that leveling kit.
Thanks so much!
That's awesome... I did too. I almost have mine competed but thinking I'm going to grab another E3D before I start calibrating.
Re: Dual extruders
Posted: Mon Jan 20, 2014 8:42 am
Thanks so much!
How do you plan to mount the E3D to the Prusa I3?
Re: Dual extruders
Posted: Mon Jan 20, 2014 10:04 am
by LorenOlepi
Eaglezsoar wrote:
Thanks so much!
I'll design a new mount ;)
Re: Dual extruders
Posted: Mon Jan 20, 2014 10:09 am
I sure hope that you are the sharing type. Hint :D
