Page 12 of 36
Re: E3D V4 All metal hotend
Posted: Mon Jan 27, 2014 7:21 pm
by gestalt73
bubbasnow wrote:YUP!
Hmm, does that mean that it doesn't matter? Ambiguous answer is ambiguous. :?
Posted: Mon Jan 27, 2014 7:30 pm
by dpmacri
Set it to 1.
threaded thermistor...
Posted: Mon Jan 27, 2014 8:00 pm
Hi all, I was looking at the E3D hot end and see that it has a through hole (about 2.5mm D) and a blind hole (2mm D). Their website says to use the blind hole for the thermistor but I've seen a few photos here that folks are using the larger through hole. I want to wrap up my E3D installation but not sure which hole to use. What is the through hole there for? Should I just carefully red rill the blind hole to 2.5mm so I can tap it M3 for my thermistor?
thanks,
Posted: Mon Jan 27, 2014 8:04 pm
by grabredemeyer
Michael, I used the blind hole as per their directions and it has worked perfectly for me. I see no reason to do it any other way.
Re: threaded thermistor...
Posted: Mon Jan 27, 2014 8:05 pm
by bubbasnow
mhackney wrote:Hi all, I was looking at the E3D hot end and see that it has a through hole (about 2.5mm D) and a blind hole (2mm D). Their website says to use the blind hole for the thermistor but I've seen a few photos here that folks are using the larger through hole. I want to wrap up my E3D installation but not sure which hole to use. What is the through hole there for? Should I just carefully red rill the blind hole to 2.5mm so I can tap it M3 for my thermistor?
thanks,
i use the hole that is next to the nozzle (the blind hole). i think if you put it at the through hole (on top of the 40W heat cartridge and one side is open) your nozzle temps would be inaccurate?
Thanks guys, just have to be careful not to drill too deep! Looks like the recommended blind hole is the way to go.
Posted: Mon Jan 27, 2014 8:07 pm
by bubbasnow
mhackney wrote:Thanks guys, just have to be careful not to drill too deep! Looks like the recommended blind hole is the way to go.
why are you drilling? i was able to tap the m3 just fine without drilling :(
Posted: Mon Jan 27, 2014 8:09 pm
I haven't drilled yet but the blind hole is 2mm (as per the data sheet) and an M3 thread requires a 2.5mm tap drill. Perhaps the aluminum is soft enough that it can be tapped without drilling?
Posted: Mon Jan 27, 2014 8:19 pm
mhackney wrote:I haven't drilled yet but the blind hole is 2mm (as per the data sheet) and an M3 thread requires a 2.5mm tap drill. Perhaps the aluminum is soft enough that it can be tapped without drilling?
Mine tapped without drilling.
Posted: Mon Jan 27, 2014 11:32 pm
by lordbinky
Did you use a cutting fluid when you tapped the aluminum, or did you just go for it?
Posted: Mon Jan 27, 2014 11:36 pm
by bubbasnow
lordbinky wrote:Did you use a cutting fluid when you tapped the aluminum, or did you just go for it?
went for it
Posted: Mon Jan 27, 2014 11:53 pm
by bvandiepenbos
aarrrggg
no no no don't tap aluminum dry.
Use some tap magic for aluminum or wd-40
http://www.mcmaster.com/#1413k42/=qfwto8
has a nice cinamon smell to :)
really works wonders tapping and machining aluminium I love it.
Posted: Tue Jan 28, 2014 8:32 am
+1 Brian. I tap literally 1000s of 2-56, 4-40 and 8-32 holes a month in brass and aluminum. In a pinch you can use a liquid soap like Dawn but tap magic is my go-to tapping fluid.
cheers,
Posted: Tue Jan 28, 2014 10:07 am
Hey guys, you seriously tapped this small hole with a M3-.5 tap without pre-drilling to 2.5mm? It doesn't even seem deep enough to get enough threads on a regular taper tap. I do have bottoming and plug taps too but none of them will start in that little blind hole. Are you sure you are not tapping the larger hole in the bottom left corner?
[img]http://mhackney.zenfolio.com/img/s11/v3 ... 5006-3.jpg[/img]
regards,
Posted: Tue Jan 28, 2014 10:23 am
mhackney wrote:Hey guys, you seriously tapped this small hole with a M3-.5 tap without pre-drilling to 2.5mm? It doesn't even seem deep enough to get enough threads on a regular taper tap. I do have bottoming and plug taps too but none of them will start in that little blind hole. Are you sure you are not tapping the larger hole in the bottom left corner?
regards,
The bottom left hole is what I used. Seemed to have worked. The screw in thermistor is threaded all the way in.
Posted: Tue Jan 28, 2014 11:27 am
Ok, the small blind hole below the thermistor in my photo is the hole recommended for the thermistor. I have no idea what the larger through hole is supposed to be for.
How about the rest of you? Did you tap the through hole in the lower corner?
Posted: Tue Jan 28, 2014 12:20 pm
mhackney wrote:Ok, the small blind hole below the thermistor in my photo is the hole recommended for the thermistor. I have no idea what the larger through hole is supposed to be for.
I believe that the large hole is there to heat your Salami.
But it works good for the thread in thermistor also.
Posted: Tue Jan 28, 2014 12:28 pm
by bubbasnow
Yea your block is different than mine...sorry for the confusion.
by Nylocke
The through hole in the heater block is for the Honeywell axial thermistor like what the buda uses. It's not recommended by E3d because they think it will give an inn accurate temp because of its placement, right next to the heater block.
Posted: Tue Jan 28, 2014 12:35 pm
Looking at the picture Michael posted if you drill out that small hole and go to deep you would be in the passage for the filament.
Posted: Tue Jan 28, 2014 1:10 pm
Eagle - exactly! I am concerned that there is not a lot of metal between the outside and the filament/nozzle passage to drill out. It could be done and I certainly have the equipment/skill to do it, but it would be tricky.
I'm just going to tap the larger through hole and use thermal paste to "plug" the end of the thermistor. I can then test the temp with my thermocouple and make a calibration curve if need be. That seems less problematic and I can always move it later if it's an issue.
Thanks all.
cheers,
Posted: Tue Jan 28, 2014 2:38 pm
by dpmacri
regards,
Umm, oops. No, that's not the hole I tapped. I don't even have a hole there :-D. I tapped the one in the lower left corner of your picture.
Posted: Tue Jan 28, 2014 4:12 pm
by Batteau62
I think depending on your version, there are different holes in these heater blocks. Probably should PM Sanjay and get some answers. :)
Posted: Tue Jan 28, 2014 6:29 pm
by bubbasnow
[img]http://files.e3d-online.com/Drawings/E3D_Heat_Block.jpg[/img]
that hole does not even exist....according to this e-drawing you should use the blind hole
Posted: Tue Jan 28, 2014 6:55 pm
Yeah, I saw that on their site. I did PM Sanjay so maybe he will chime in. For now, I've tapped the 2.5mm through hole that is in my heater block.
