Page 2 of 2
Re: Parts that I printed are too big
Posted: Tue Nov 03, 2015 1:32 pm
Your missing steps, take a close look at the tower it's either leaning towards or leaning away from, it's probably a mechanical issue, but it can be bad endstop wiring, or the stepper current set too high or too low.
Posted: Tue Nov 03, 2015 2:22 pm
by Tincho85
I would also check belts.
Posted: Tue Nov 03, 2015 8:58 pm
by dsl158
Tincho85 wrote:I would also check belts.
After checking the belts and changing the steps per mm to 80 the size problem is fine but now its just the layer shifting
Posted: Mon Nov 09, 2015 9:29 pm
by Right to Make
could you check your print speeds? you may be overshooting the target layer. Print something very slowly and max speed to very slow and watch. ??? just trying to brain storm.
