LCD screen not coming up after successful flash
dsnettleton
Re: LCD screen not coming up after successful flash
Post by dsnettleton »
Is there a good guide somewhere for flashing repetier firmware onto a rostock? I had to make several changes to the Marlin firmware, and I'm not eager to repeat the troubleshooting process.
Trust me, sir. I'm a wizard.
bplemmons
Post by bplemmons »
Even though John said I had a bad display, I received the new on and it does the same thing....
Anyone willing to try my firmware?
John keeps saying that it has to be the problem, I know I went over the instruction 30 times at least!
Bill
cambo3d
Post by cambo3d »
bill have you tried the repetier firmware, there are reports that marlin isn't working for some.
bplemmons
Post by bplemmons »
Is that the polygonhell one? if so, I did and same result, if not can you post a link and I would love to try it....
Bill
cambo3d
Post by cambo3d »
bplemmons wrote:Is that the polygonhell one? if so, I did and same result, if not can you post a link and I would love to try it....
Bill
that's it look for his post on the forum, i used it with my new lcd and it works with no tinkering to the firmware. https://github.com/polygonhell/Repetier-Firmware
I used arduino 1.o3 to upload it.
bplemmons
Post by bplemmons »
That was it!!! Thank you!!!! I was using the wrong ver. of Aurdrino (023) for the polygonhell firmware....
Bill
oeginc
Post by oeginc »
I got Marlin firmware to work pretty easily, and I used Arduino 1.0.4
The one gotcha you have to watch out is that you are pasting the code in the right spot. Some of the files have multiple defines (Ie: #ifdef MOTHERBOARD = 301), and you have to be sure you are in the right section for your motherboard (RAMBO = 301).
Before I fixed the firmware, I jut got boxes on my LCD.
If you are still having problems, let me know I can create a small how-to.
bplemmons
Post by bplemmons »
I think that a how to would be a great idea!
cambo3d
Post by cambo3d »
or just post the working firmware so we wont have to go through all that trouble. I had both firmwares working on my lcd, it was just my lcd was bad.
jesse
Post by jesse »
cambo3d wrote:or just post the working firmware so we wont have to go through all that trouble.
A zip file with the arduino environment and the firmware would be nice to have.
bplemmons
Post by bplemmons »
I attached my Aurdrino 0023 with the pin files changed and my Marlin with my changes per the directions ( warning if you load this on your printer it will have my Z home and pid files)
If someone would care to review them I would love to know what i'm doing wrong. I did get polygonhell to work but I would love to know why this one doesn't work for me...
Thanks
Marlin.zip
(1 MiB) Downloaded 368 times
bplemmons
Post by bplemmons »
Hmmm, I tried uploading the Arduino file several times and It doesn't upload, Is there a size restriction or something?
Someone can look at Marlin anyway....
Bill
jesse
Post by jesse »
SeeMeCNC tested my LCD and found it to be working. The problem was probably with the cable I made.
They sent me an adapter which I soldered together and hooked it up. That worked fine.
I ran the installer from the SeeMeCNC website and updated the firmware to the oldest Rambo settings.
