Re: Duet setup - instructions in progress
Posted: Sun Feb 14, 2016 1:34 pm
Come on guys discuss this some more, I am learning a lot with all the postings going on.
Have a look around and join today!
https://images.seemecnc.com/
I'm not sure what you mean exactly by "need to be explicit". I wasn't aware there was a vague way of picking "Relative" or "Absolute" in Kisslicer.mhackney wrote:You can use either but you just need to be explicit. I use Relative because I've developed a lot of post processing scripts to do special things and they work with Relative extrusion.
I am not on the fence you have convinced megeneb wrote:
If you're on the fence on buying a Duet and you've either already got FSRs installed or have some other Z-probe, BUY. THIS. BOARD. You won't regret the upgrade.
That's what I meant by being explicit.geneb wrote:Yep, that's where I stepped in it. The default in config.g is M83, which explains why the extruder lost its little mind when fed absolutes.
tnx.
mhackney wrote:I think they can be common ground but most just run a twisted pair up to each endstop. What'd the motivation to do it differently?
+1 for powerpoles. I use them on lots of stuff on my printer.dbarrans wrote:http://www.powerwerx.com/anderson-powerpoles/
It is tough to be retired and keep money in the grouch bag isn't it? Also there and it is tough. I am glad that it worked out for you.Windshadow wrote:I am not on the fence you have convinced megeneb wrote:
g.![]()
But this is winter heating season in Maine and when I woke up this morning at about 6:30 it was -15f outside and the temp in my house was 45f in my bed room.... a fast decent to the basement found the furnace was not firing I hit the reset switch and the burner motor came on but no fire just a stink of raw fuel oil I tried reset once more and the same thing and a total reek of fuel oil.... called the folks that service my furnace with whom I have a $150 a year "Defender" service policy and got fires going in all 6 of my fireplaces to preserve the pipes from another freeze up. the service found a totally dead igniter box and heat was restored by 10am whew... the point is that i need to keep extra cash in the grouch bag in the winter.
so I will be doing this but I see that a new rev of the Duet is due this spring and perhaps by then the SeeMeCNC probe will also will be ready as will your fool proof installation instructions for this fool to do the upgrade
Dr Mengela?geneb wrote:Got any grandkids you can sell for science experiments?
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/bossac -e -w -v -b RepRapFirmware-XXX-DD-MM-YYYY.bin
Is X -0.22° Y -0.16° Z 0.00 specific corrections to your printer?M665 R182.55 L288.0 B105 H255.83 X -0.22° Y -0.16° Z 0.00
