Page 7 of 19
Posted: Mon May 13, 2013 12:44 am
by CosplayEngineer
xnaron wrote:Because there are too many Yoda's...
Printed at 200mm/s in 45min. It is 100mm high.
..all I want is to be able to print out a good bridge. Wow.
Posted: Mon May 13, 2013 1:47 am
by bplemmons
http://store.kysanelectronics.com/servl ... -C6/Detail
Is this the right stepper for the extruder upgrade?
thanks
Bill
Posted: Mon May 13, 2013 10:13 am
by xnaron
bplemmons wrote:Wow, that extruder looks amazing. you are really taking the Rostock to a new level..
Can you share your source for the stepper?
Thanks for sharing your amazing upgrades!!
Bill
All the details are on the first page of this thread ;)
Posted: Mon May 13, 2013 10:14 am
by xnaron
Eaglezsoar wrote:Xnaron: Would it be possible for you to post the squirrel cage fan mounts that you created to hold those squirrel cage fans
you are using?
oops I missed this one in my PM's. The fan mount was from os1r1s. I have asked him to share it. He is going to put it on his github. I will remind him again :) As soon as he does I will link it on the first page.
Posted: Mon May 13, 2013 10:17 am
by xnaron
with bridging it is important that you have your flow rate and nozzle size specified correctly. I always go about 10% higher for nozzle size (extrusion width). So for 0.5mm nozzle I specify it as 0.55mm. Just for fun try setting your extrusion width to 0.7mm and see how that affects your bridging.
Posted: Mon May 13, 2013 10:19 am
by xnaron
bplemmons wrote:http://store.kysanelectronics.com/servl ... -C6/Detail
thanks
Bill
I have the link to the stepper on the first page in the Bowden Extruder category.
Posted: Mon May 13, 2013 11:15 am
you are using?
Posted: Mon May 13, 2013 11:51 am
by Broose
Xnaron- What is the inside diameter the boom end supposed to be? I seem to have an XY scaling problem, or part of it may be shrinkage of ABS. My ID came out to .362 in. and I would think it should be closer to .375 in. I can't fit the magnets in without drilling first, and that creates an issue with the bottom of the hole.
Posted: Mon May 13, 2013 1:37 pm
by Broose
you are using?
Is this it?
https://github.com/os1r1s-/misc-parts/b ... ductv2.stl
Posted: Mon May 13, 2013 3:13 pm
you are using?
Is this it?
Yes that is it! :P
Thanks to Xnaron for posting it, and thanks to Broose for finding it! :D
That's not even under Xnaron's files, how did you find it? Great Job!
Posted: Tue May 14, 2013 10:12 am
by xnaron
Here is the os1r1s fan mount that I used https://github.com/os1r1s-/misc-parts
Posted: Tue May 14, 2013 11:44 am
by cambo3d
I milled out xnaron's heat shield from aluminum as a favor to another member for helping me out. here's what it looks like before clean up.
Posted: Wed May 15, 2013 1:56 am
by bplemmons
Wow, those are awesome, He is a lucky guy.....:)
Posted: Wed May 15, 2013 1:58 am
by cambo3d
lol, you only get one. the other is mine.
Posted: Wed May 15, 2013 4:27 am
by bplemmons
How come you have to use 6 arms with deltas? Wouldn't 3 (magnetic) arms do the job?
Bill
Posted: Wed May 15, 2013 4:33 am
by ApacheXMD
While three arms and thus three points would define the plane of the effector (print platform), I would think that with only three arms, the effector would still tend to rotate about the vertical axis.
Posted: Wed May 15, 2013 5:08 am
bplemmons wrote:How come you have to use 6 arms with deltas? Wouldn't 3 (magnetic) arms do the job?
Bill
You could use just 3 arms if the joint you used made it impossible for the arm to rotate relative to the tower and relative to the platform in practice it's hard to get enough rotational stiffness with a single arm, so pairs are used.
Posted: Wed May 15, 2013 5:12 am
by bplemmons
That makes a lot of sense, Thanks
Posted: Sat May 18, 2013 2:59 pm
by xnaron
I wanted to be able to print at a finer resolution so I built a 0.35mm J-head effector for the Magnarms. This one has a 30W heater cartridge. I turned retraction down from 4.5mm to 2.5mm. The results are amazing.
Posted: Sat May 18, 2013 3:54 pm
by cambo3d
Xnaron,
You wouldn't have a dxf file of the effector mount would you. I want to mill one out of aluminum instead of the printed parts. I drew one up base on your photos/stls but i dont think its correct.
Posted: Sat May 18, 2013 5:05 pm
cambo3d wrote:Xnaron,
If you are able to fabricate the effector from aluminum, I would be interested in two.
I would be interested in aluminum cheapskate mounts also.
Posted: Sat May 18, 2013 5:26 pm
by Broose
Make sure you get a good connection with jb welding the 3mm cap screw to the ball bearing. I had one come off during a print. I had properly prepped the ball bearing and screw with acetone and cured under a lamp.
No damage, but a mess of a print. In repairing it, I was able to use 320 grit sandpaper to sand through or at least abrade the section of the chrome surface of the ball where the cap screw is attached. I am hoping that will make for a better connection.
Posted: Sun May 19, 2013 1:43 am
by xnaron
Retraction nailed!
Posted: Sun May 19, 2013 3:00 pm
by cambo3d
im gonna try without bending first, looks like there might be room.
Posted: Sun May 19, 2013 3:16 pm
by Broose
cambo3d wrote:im gonna try without bending first, looks like there might be room.
It looks like the only problem would be if a cheapskate dropped below the effector, which shouldn't happen under normal use.
