EZStruder synced with Z stepper
brianmichalk
Post by brianmichalk »
Newbie here.
Just built my V3 and the extruder stepper seems to be getting the same commands as the Z stepper. Would this be an Arduino configuration problem? I thought I followed the instructions correctly.
Re: EZStruder synced with Z stepper
You probably have it plugged into the wrong port on the RAMBO, remember there are 2 Z stepper connectors next to each other that get the same signals.
brianmichalk
Thanks, you were correct. I moved it over to E0, and am now waiting on the bed to come up to temp. I did try the manual control in MarrterControl to move the filament, but the filament feeder didn't do anything. I'll see in a few minutes if the print job moves filament.
Noircogi
Post by Noircogi »
The extruder has a software safety lock. It will only run if the hot end is up to temp.
Return to “RostockMAX v3”
