Help setting up FSR on Maxv2 /Rambo
Re: Help setting up FSR on Maxv2 /Rambo
geneb wrote:So basically, we're talking cow hooves per square ounce, right?
I think it's carat-ounces :)
[img]http://i.imgur.com/iDOzAa5.jpg[/img]
Thanks for the clarification, Michael! Yeah, force - not weight... Derp. Makes much more sense now.
LOL! I love that answer!
Well ya gotta admit, it's right in the name. Force Sensitive Resistor. :)
(what book is the page scanned from?)
I wasn't thinking of the physics definition of force, I was thinking about the FSRs like a load cell...
I guess for those that don't get the difference, it's all about change. It's the delta of force, like a car accelerating compared to going the same speed. Not how much you weigh, but how much you make the elevator bounce when you jump :)
Not sure about the book, I always just google it.
Would a horse work?
No horsing around Eaglezsoar!
enggmaug
Post by enggmaug »
I feel like there is some confusion in what has been said here. I'm sorry if I repeat what has been already said, or if it's not really the subject of the thread, but I believe I need to intervene.
FSRs are like weigthing scales. When you depress on a scale, the displayed value changes. When you depress on FSR, their resistive value changes in the same way.
Weighting scales, as well as FSR, actually measure the force applied onto them (in Newtons).
If you place whatever object on an FSR, the mass of the object combined with earth gravity applies a constant force on it as long as the object is there. The output of the FSR is thus constant... like when you climb on your scale.
Now you remove the object, the output of FSR changes, but that new value remains constant...
The magic comes from the interface board. This board detects when there are changes in FSR outputs, and it is the interface board that triggers a signal to indicate that the force applied on the FSR is different. If you have a digital weighting scale, it probably turns on when you step on it. It will not stay on if you stand there for hours. The digital weighting scales detects when you step on it the same way the FSR interface board does.
The confusion bewtween force and mass is actually coming from the weighting scales. They translate the force in Newtons applied onto them to a weight in Grams by supposing that earth gravity is constant... and it is false, but acceptable by many.
barry99705
Post by barry99705 »
geneb wrote:Well ya gotta admit, it's right in the name. Force Sensitive Resistor. :)
https://kindle.amazon.com/work/wild-thi ... 0316032190
Thanks barry!
Thanks enggmaug, you explained it very well so that even I can understand, you da man!
My FLUX printer came in this week, and it uses FSRs to level and calibrate. I'm pretty impressed.
[youtube]http://www.youtube.com/watch?v=TcLhqFXAmN0[/youtube]
Definitely doing this to my Rostock ASAP.
Very odd probing behavior! A single probe at each point is all that's needed.
That is an interesting looking printer!
mhackney wrote:Very odd probing behavior! A single probe at each point is all that's needed.
It taps each point 6 or 7 times, and it moves down a little bit each time. You can hear it "ting" on the metal bed the last 2 times of each cycle...
Windshadow
Post by Windshadow »
You must have been an early supporter to get one this early. How is the engraver gadget? Have you done a review of it yet?
NM i see it here
http://forum.seemecnc.com/viewtopic.php?f=61&t=9911
DeltaCon
Post by DeltaCon »
My guess is that it does probe more often at each point to tune in to exact zero point while compensating for the momentum of the head at the time of the impact.
