Heated bed does not heat.
velocilobster
Post by velocilobster »
I have been having problems with bed adhesion for the last few weeks, on troubleshooting today after a calibration run I noticed that the bed does not want to heat up anymore.
I have noticed that when turning heat (for the bed) on, the LED does not flicker anymore, however the thermistor is reading temperature still.
I am assuming this is most likely a blown fuse, I have not taken the bed apart because I wanted to get some insight before I went down that route. What is the location/code for this on the board? Any other troubleshooting tips to figure this out?
Thanks.
v2 with e3d v6, CF arms.
teoman
Re: Heated bed does not heat.
Post by teoman »
The fuse is an automotive fuse.
It is the big one that sticks out. Can't miss it.
Check the cables aswell.
velocilobster
Checked the fuse...I think I found the issue.... :lol: :lol: :lol:
[img]http://i.imgur.com/pKx5Wf3.jpg?1[/img]
teoman
Post by teoman »
I had the Exact same problem.
Check out my thread for a fix.
