Arduino Board setting?
cassetti
Post by cassetti »
Question? I know what port to use, but what board do i select? Current it's set to Azteeg X1. I'm pretty sure that's not what I want.
I'm running Arduino 1.0.1
cambo3d
Re: Arduino Board setting?
Post by cambo3d »
arduino mega
but you should use arduino 22 or 23 if your installing marlin firmware.
you can use arduino 1.03 with repetier firmware.
cassetti
Post by cassetti »
Wait, I just saw something about installing using repetier-host, is that true?
i'm trying to use Polygonhell's version of the firmware.....
cambo3d
Post by cambo3d »
repetier host and repetier firmware are two different things.
use arduino 1.03 if your installing poly's repetier firmware then because its known to work.
cassetti
Post by cassetti »
cambo3d wrote:repetier host and repetier firmware are two different things.
use arduino 1.03 if your installing poly's repetier firmware then.
Gotcha, and I want to select the board "Mega 2560" to be specific, correct?
cambo3d
Post by cambo3d »
yes, rambo is based on arduino mega 2560
Return to “The Build Zone”
