I was using a 2.5 mm hex bit to open and close the extruder.
The 2.5 mm bit is too small and stripped the screw.
The distance on the e-drawing shows that hole to be 2.893 mm or 0.114 inches.
I tried 3 mm and it's definitely too large. The closest size seems to be 7/64 inch.
Does anyone know what the exact hex bit/allen key size is?
Where can the 1/4" or 1/8" type bit be purchased?
[img]http://i.imgur.com/g0iXMdH.jpg[/img]
Correct hex bit for 6-32 2000L
Re: Correct hex bit for 6-32 2000L
I got a set of many many bits from a supermarket for a few euro. Yes, 7/64" should be right.
- Prints-a-lot
I've just checked my machine, and its a good fit on a 7/64 allen key. I find it helps having a decent quality set, the fit is always better.
I found a bit set with the 7/64 hex/allen bit. The keywords are "33 bit security".
[img]http://i.imgur.com/1FZxQ5E.jpg[/img]
eBay ($5.25)
Harbor Freight ($5.99)
eBay ($5.25)
You do not need necessarily the security bits with the holes. But it should work.
