Its a friend's laser. Thats a bit of an old picture when I originally cut the parts out.
The Ultimaker is a pretty easy printer to build (at least the frame and stuff) so I probably won't have a huge amount of build pictures. I will definitely have plenty of print pictures though.
- Box Frame
- Hackimaker :D
The frame has some customness to it. Its taller than the regular Ultimaker. Its actually not to get additional Z height (though if I was thinking a bit more that could've been something I could've done). I have it so I can fit a RAMPS (while its still a shield like the Ultimaker Electronics, the fuses take up more "height" on the RAMPS), beefier PSU, and a larger stepper on the Z axis. I have hole patterns for RAMPS, RAMBo, the Ultimaker electronics, and PSUs like this
http://www.youyipower.com/blog/files/20 ... supply.jpg.
- Z Stage
The main bit that I've had to design from scratch was a nut holder. You can buy a nut similar to the one on the Ultimaker Original from aliexpress or something like that, but I'm hesitant to buy something for a place as sketchy as that, so instead I got one of the 8mm ACME leadscrews from OpenBuilds and one of the nuts to go with it and designed a block for it to fit into. Its hard to see in the picture (black filament + nut) but it works. I have some stuff to tweak on the design, and I may have to reposition things (not entirely sure if the nut is positioned in the right spot), but it seems like it will work well when I get it all sorted out.
- Nut block (nut is on top, secured with M4 CHS)
- Nut Block in CAD
Painting wise, I'm a fan of the bare birch look. I might stain it (I have plenty of extra pieces that I can run tests on) or something though.
