Tried the SD card with the G-code from Slic3r which turned on the bed but not the HotEnd. But as I type this I think I remember reading that somewhere some prints heat the bed first then the tip. So maybe that was OK?? Will plug the SD in again soon. At least I have begun to work through and understand Slic3r, KISS Slicer and Cura. I've learned much with this problem.
Most importantly I figured out the fill issue!!!
Spiral Vase!! When I unchecked the Spiral Vase checkbox the fill problem went away.!!!
I'm not sure why since the parts I have been printing have been single parts.
I also learned that on MC I can generate the G-code in the layer view before printing which allowed me to quickly scroll through the print to see if the infill had been built. This allowed me to delete all my saved slice configurations, load the "standard" and quickly step by step work through each option until I found the gremlin.
Printing AGAIN!!!
