Taller objects having warping issues
netdefilr
Post by netdefilr »
Not sure how to solve this. But the pictures could explain what is happening.
craftymethod
Re: Taller objects having warping issues
Post by craftymethod »
are those three seperate pieces?
BenTheRighteous
Post by BenTheRighteous »
Is that ABS? Unless you need the strength, I recommend printing big decorative pieces out of PLA to save yourself the headache of warping.
JFettig
Post by JFettig »
Abs likes to crack and warp unless temps can be held high. Build an enclosure that holds in the heat. What is your nozzle temp? I keep mine 235-240 which helps
netdefilr
Post by netdefilr »
I used ABS. I'm trying to print with PLA now instead for larger pieces. I believe that was printed at 225.
