New EVGA power supply wiring question
jram
Post by jram »
Hello All,
I just bought an EVGA supernova NEX650G to power my Max v2, the included diablotek crapped out during calibration. Support is great, they are sending a new Viotek but I'll use that one as a backup. I'm wondering how I go about wiring this?(I'm a noobie when it comes to wiring and I want to be sure to not fry the machine! I have attached a few images, the wires are all black and there are no other colors so I'm a bit confused. Also, do I still bundle 4 together like I did with the Diablotek?(once I find out which 4 to bundle
Re: New EVGA power supply wiring question
Post by Mac The Knife »
If you have the connector you cut from the other psu, you could use it as a guide. The wires may be all black on the new one, but the pin positions are the same.
Kevinvandeusen
Post by Kevinvandeusen »
Here you go!
jram
Post by jram »
Kevinvandeusen wrote:Here you go!
Thank you!!
add1ct3dd
Post by add1ct3dd »
You will need to make sure you use multiple 12v lines.
jram
Post by jram »
Thanks guys, I wired it up last night and now the bed and hot end will actually reach target temp and stay there. Now I'm just working on an ezstruder issue.
Return to “Rostock MAX v2”
